How to make a small Gas Jet Cutter
Миниатурная газовая горелкаMini gas jet
I needed a small gas burner for the thermomagnetic engine project (based on the Curie point). I thought that this simple construction might be of interest to you.
The process of assembly and testing is shown in the video clip
Gas burner assembly.
To implement this project, the following products were used: a medical dropper, a broken telescopic antenna and the cheapest Chinese gas burner.
The gas burner is working
That’s what the burner looks like when it’s assembled.
Guess what it is?
To show the gas burner in operation, I made a small device, which I will describe in one of the following video clips. I hope you can guess how you can use this gadget.
Handmade Small Gas Jet Improvement Part 2
Thanks to the constructive criticism of one subscriber, the blog produced a new burner. Size became larger and the flame size is reduced. The temperature also increased. The gas is afterburned, since there are no yellow flames. The temperature, judging by the color of the hot steel, reaches 1200 ° C.
The assembly of the burner has even become simpler, and the reliability of the needle attachment has increased.
This video shows a new gas burner and its test
Related topics
How to Make a Camera Slider
How to Make a Compact Camera Slider for $5
Smoke Machine 200 watts DIY
Portable tripod head for half an hour with your own hands
Не удивляйтесь! Эти адреса не связаны со статьей, но они проверены и даже могут представлять интерес для Вас или ваших друзей. Ну вот и всё, главное красиво и ненавязчиво закончить мысль. Всем удачи!
Спасибо за помощь!
Комментарии закрыты.
